Article
Building Plans for Foundations with 1-1/2 in. of rigid Foam Insulation
How to design and build an energy efficient foundation: monolithic slabs, Frost-wall slabs, crawl spaces, and basements built with poured concrete or block.
TK Detail drawings in this collection featuring 1-1/2 in. of exterior foam:
CRAWL SPACE FOUNDATION
Poured Concrete w/ Interior FoamDOWNLOAD: PDF
| DWG
Poured Concrete w/ Exterior FoamDOWNLOAD: PDF
| DWG
Block wall w/ Exterior FoamDOWNLOAD: PDF
| DWG
Block wall w/ Interior FoamDOWNLOAD: PDF
| DWG
BECOME A MEMBER AND GET FULL ACCESS TO GREEN BUILDING ADVISOR
SLABS
Slab on Grade with Frost WallDOWNLOAD: [PDF]() | [DWG]()
Frost-Protected Monolithic SlabDOWNLOAD: PDF
| DWG
| DWG
Monolithic to Garage Slab TransitionDOWNLOAD: PDF
| DWG
GBA Pro members get full access to the Construction Detail Library.
Join Now.
Don’t want to become a GBA Pro?
BUY THIS PACKAGE IN THE FINE HOMEBUILDING STORE
BASEMENTS
Block wall, Exterior Foam — DOWNLOAD: PDF
| DWG
Block wall, Interior Foam (Framed Wall)DOWNLOAD: PDF
| DWG
Block wall, Interior Foam & Furring StripsDOWNLOAD: PDF
| DWG
Poured Concrete, Exterior FoamDOWNLOAD: PDF
| DWG
Poured Concrete, Interior Foam (Furring Strips)DOWNLOAD: PDF
| DWG
Join Now.
Detail Packages that can make old houses energy efficient:
