How To Keep Water and Radon Out of Your Basement or Crawlspace: 8 Details that will keep your foundation dry and healthy
GBA PRO members have total access to all of the construction details.
EXTERIOR FOUNDATION WATER MANAGEMENT
Perimeter Drain to French Drain — DOWNLOAD: PDF
| DWG
Foundation Footing Drain — DOWNLOAD: PDF
| (No DWG )
FREE SAMPLE:
Underground Water Barrier Retrofit — DOWNLOAD: PDF
| DWG
GBA Pro members get full access toB the Construction Detail Library.
Join Now.
INTERIOR WATER MANAGEMENT
Interior and Exterior Drains — DOWNLOAD: PDF
| DWG
Interior Footing Drain, Insulated Slab — DOWNLOAD: PDF
| DWG
Interior Footing Drain, Rubble Wall — DOWNLOAD: PDF
| DWG
RADON MITIGATION
Wall Section w/ Interior Drain & Sump — DOWNLOAD: PDF
| DWG
Sub-Slab Radon Retrofit — DOWNLOAD: PDF
| DWG
BECOME A MEMBER AND GET FULL ACCESS TO GREEN BUILDING ADVISOR
