As Solar Panels Age Out, Recyclers Hope to Cash In
Solar panels have a lifespan of 25 to 30 years and contain valuable metals, including silver and copper
Mexico's Villanueva solar plant, the largest solar farm in the Americas. Photo courtesy Enel.
This article originally appeared at Yale Environment 360.
In Odessa, Texas, workers at a startup called SolarCycle unload trucks carrying end-of-life photovoltaic panels freshly picked from commercial solar farms across the United States. They separate the panels from the aluminum frames and electrical boxes, then feed them into machines that detach their glass from the laminated materials that have helped generate electricity from sunlight for about a quarter of a century.
Next, the panels are ground, shredded, and subjected to a patented process that extracts the valuable materials—mostly silver, copper, and crystalline silicon. Those components will be sold, as will the lower-value aluminum and glass, which may even end up in the next generation of solar panels.
This process offers a glimpse of what could happen to an expected surge of retired solar panels that will stream from an industry that represents the fastest-growing source of energy in the U.S. Today, roughly 90% of panels in the U.S. that have lost their efficiency due to age, or that are defective, end up in landfills because that option costs a fraction of recycling them.
But recycling advocates in the U.S. say increased reuse of valuable materials, like silver and copper, would help boost the circular economy, in which waste and pollution are reduced by constantly reusing materials. According to a 2021 report by the National Renewable Energy Laboratory (NREL), recycling PV panels could also cut the risk of landfills leaking toxins into the environment; increase the stability of a supply chain that is largely dependent on imports from Southeast Asia; lower the cost of raw materials to solar and other types of manufacturers; and expand market opportunities for U.S. recyclers.
Of course, reusing degraded but still-functional panels is an even better option. Millions of these panels now end up in developing nations, while others are reused closer to home. For example, SolarCycle is building a power plant for its Texas factory that will use refurbished modules.
The prospect of a future glut of expired panels is prompting efforts by a handful of solar recyclers to address a mismatch between the current buildup of renewable energy capacity by utilities, cities, and private companies—millions of panels are installed globally every year—and a shortage of facilities that can handle this material safely when it reaches the end of its useful life, in about 25 to 30 years.
Solar capacity across all segments in the U.S. is expected to rise by an average of 21% a year from 2023 to 2027, according to the latest quarterly report from the Solar Energy Industries Association and the consulting firm Wood Mackenzie. The expected increase will be helped by the landmark Inflation Reduction Act of 2022 which, among other supports for renewable energy, will provide a 30% tax credit for residential solar installations.
The area covered by solar panels that were installed in the U.S. as of 2021 and are due to retire by 2030 would cover about 3,000 American football fields, according to an NREL estimate. “It’s a good bit of waste,” said Taylor Curtis, a legal and regulatory analyst at the lab. But the industry’s recycling rate, at less than 10%, lags far behind the upbeat forecasts for the industry’s growth.
Laminate removed from a solar panel is examined at SolarCycle’s facility in Odessa, Texas. The laminate contains silicon, copper, and silver. SolarCycle
Jesse Simons, a co-founder of SolarCycle, which employs about 30 people and began operations last December, said solid waste landfills typically charge $1 to $2 to accept a solar panel, rising to around $5 if the material is deemed hazardous waste. By contrast, his company charges $18 per panel. Clients are willing to pay that rate because they may be unable to find a landfill licensed to accept hazardous waste and assume legal liability for it, and because they want to minimize the environmental impact of their old panels, said Simons, a former Sierra Club executive.
SolarCycle provides its clients with an environmental analysis that shows the benefits of panel recycling. For example, recycling aluminum uses 95% less energy than making virgin aluminum, which bears the costs of mining the raw material, bauxite, and then transporting and refining it.
The company estimates that recycling each panel avoids the emissions of 97 pounds of CO2; the figure rises to more than 1.5 tons of CO2 if a panel is reused. Under a proposed Securities and Exchange Commission rule, publicly held companies will be required to disclose climate-related risks that are likely to have a material impact on their business, including their greenhouse gas emissions.
Stripped from solar panels at the SolarCycle plant, aluminum is sold at a nearby metal yard. Glass is currently sold for just a few cents per panel for reuse in basic products like bottles, but Simons hopes he will eventually have enough of it to sell for a higher price to a manufacturer of new solar panel sheets.
Crystalline silicon, used as a base material in solar cells, is also worth recovering, he said. Although it must be refined for use in future panels, its use avoids the environmental impacts of mining and processing new silicon.
SolarCycle is one of only five companies in the U.S. listed by the SEIA as capable of providing recycling services. The industry remains in its infancy and is still figuring out how to make money from recovering and then selling panel components, according to the U.S. Environmental Protection Agency. “Elements of this recycling process can be found in the United States, but it is not yet happening on a large scale,“ the EPA said in an overview of the industry.
In 2016, the International Renewable Energy Agency (IRENA) forecast that by the early 2030s, the global quantity of decommissioned PV panels will equal some 4% of the number of installed panels. By the 2050s, the volume of solar panel waste will rise to at least 5 million metric tons a year, the agency said. China, the world’s biggest producer of solar energy, is expected to have retired a cumulative total of at least 13.5 million metric tons of panels by 2050, by far the largest quantity among major solar-producing nations and nearly twice the volume the U.S. will retire by that time, according to the IRENA report.
The raw materials technically recoverable from PV panels globally could cumulatively be worth $450 million (in 2016 terms) by 2030, the report found, about equal to the cost of raw materials needed to produce some 60 million new panels, or 18 gigawatts of power-generation capacity. By 2050, the report said, recoverable value could cumulatively exceed $15 billion.
For now, though, solar recyclers face significant economic, technological, and regulatory challenges. Part of the problem, says NREL’s Curtis, is a lack of data on panel recycling rates, which hinders potential policy responses that might provide more incentives for solar-farm operators to recycle end-of-life panels rather than dump them
Another problem is that the Toxicity Characteristic Leaching Procedure—an EPA-approved method used to determine whether a product or material contains hazardous elements that could leach into the environment—is known to be faulty. Consequently, some solar farm owners end up “over-managing” their panels as hazardous without making a formal hazardous-waste determination, Curtis said. They end up paying more to dispose of them in landfills permitted to handle hazardous waste or to recycle them.
The International Energy Agency assessed whether solar panels that contain lead, cadmium, and selenium would impact human health if dumped in either hazardous-waste or municipal landfills and determined the risk was low. Still, the agency said in a 2020 report, its findings did not constitute an endorsement of landfilling: Recycling, it stated, would “further mitigate” environmental concerns.
NREL is currently studying an alternative process for determining whether or not panels are hazardous. “We need to figure that out because it is definitely impacting the liability and the cost to make recycling more competitive,” Curtis said.
Despite these uncertainties, four states recently enacted laws addressing PV module recycling. California, which has the most solar installations, allows panels to be dumped in landfills, but only after they have been verified as non-hazardous by a designated laboratory, which can cost upwards of $1,500. As of July 2022, California had only one recycling plant that accepted solar panels.
In Washington State, a law designed to provide an environmentally sound way to recycle PV panels is due to be implemented in July of 2025; New Jersey officials expect to issue a report on managing PV waste this spring; and North Carolina has directed state environmental officials to study the decommissioning of utility scale solar projects. (North Carolina currently requires solar panels to be disposed of as hazardous waste if they contain heavy metals like silver or—in the case of older panels—hexavalent chromium, lead, cadmium, and arsenic.)
In the European Union, end-of-life photovoltaic panels have, since 2012, been treated as electronic waste under the EU’s waste electrical and electronic equipment directive, known as WEEE. The directive requires all member states to comply with minimum standards, but the actual rate of e-waste recycling varies from nation to nation, said Marius Mordal Bakke, senior analyst for solar supplier research at Rystad Energy, a research firm headquartered in Oslo, Norway. Despite this law, the EU’s PV recycling rate is no better than the U.S. rate—around 10%—largely because of the difficulty of extracting valuable materials from panels, Bakke said.
But he predicted that recycling will become more prevalent when the number of end-of-life panels rises to the point where it presents a business opportunity, providing recyclers with valuable materials they can sell. Governments can help speed that transition, he added, by banning the disposal of PV panels in landfills and providing incentives such as tax breaks to anyone who uses solar panels.
“At some point in the future, you are going to see enough panels being decommissioned that you kind of have to start recycling,” Bakke said. “It will become profitable by itself regardless of commodity prices.”
Jon Hurdle is a freelance journalist and a regular contributor to The New York Times on a variety of topics.
7 Comments
  1. StephenSheehy | | #1
    Solar panels lose their efficiency very slowly. After eight years, my panels still produce pretty much the same amount of electricity in a year. Our best output (7970 kwh) was year one, 2016. Second best(7940 kwh) was 2022. Annual weather variation is a much more significant factor. So the assumption that after 25 years, panels will be no longer useful is simply wrong.
      Michael Maines | | #2
      I have heard estimates that panels lose about 1% efficiency each year, on average, but that it varies. I know there are cases where they simply stop working at all, but I wonder what the assumptions are behind the idea that they have a 25-year lifespan. I bet there a market for lower-efficiency panels, if the price is right.
      1. StephenSheehy | | #3
        I think most panels are warranted to produce 80% of original over the 25 year typical warranty period. My experience is only one anecdote. But over 7 calendar years, output has varied between a high of 7970 kwh in 2016 and 7610 kwh in 2017. Every other year is between those.
        Interestingly, the single highest daily production ever was on a day in May 2020. Lowest daily high for the year was on a day in May 2016. I suspect the annual high is always in May, not right at the solstice because maximum output is on clear, cool days. By the time summer rolls around, it's warmer and sunny days tend to be a little bit hazy.
        The primary benefit to newer panels is that they take up less space for the same amount of potential output. My panels were rated at 280 watts. Newer panels are well over 400 watts. So I assume there's a market for older panels somewhere. But since panels are a cheap commodity, the total cost of installation, including labor, racks, etc. won't vary all that much between older panels and newer ones. And if space is limited, you get more power with newer panels.
  2. Jacob_D | | #4
    Can anyone point to any studies that demonstrate just how bad 30 year old solar panels are? And does every panel degrade at the same rate? And other than planned obsolescence, is there any good reason the industry can't make longer lasting panels? Seems like a lot of was baked into they system.
    1. mateohao | | #6
      Jacob, solar panels degrade at different rates depending on the size and purity of the silicon crystal (mono-crystalline vs poly-crystalline, whole cell vs half-cell), the cell chemistry (PERC vs TOPCon), the number of bus bars on each cell to transport electrons, the durability of the sealants around the edge of the module lamination, and of course the variables of the environment they are installed in.
      For example, Light Induced Degradation (LID) occurs when electrons can get trapped inside matrices created by oxygen inside the silicon interacting with boron dopants, permanently reducing cell efficiency. This usually happens when the panels are first exposed to the sun.
      Light and elevated Temperature Induced Degradation (LeTID) is more insidious problem that happens over a long period of time, and the mechanism is still not fully understood, but is directly proportional to extreme heat, sun, and the temperature at which the silicon cells were manufactured .
      If a tree consistently shades a portion of your panel, the electrons can run in reverse, creating a hot spot that will prematurely burn-out your panel.
      Clamping your module too tightly to your roof or rack can introduce micro-fractures, which worsen over time with thermal cycling, and will influence electron flow, leading to hot spots and oxidation.
      The 30-year figure represents the industry standard "Performance Warranty". It is what the industry agreed is a reasonable period to guarantee a utility company or PV distributor's investments. "80% in 25 years" represents a typical figure. As technology and efficiency improves, modules of the future will no doubt last longer. Warranty periods will probably go up, too, since a guaranteed performance envelope is commensurate with a higher MSRP.
  3. MartinHolladay | | #5
    Jacob,
    Q. "Can anyone point to any studies that demonstrate just how bad 30 year old solar panels are?"
    A. This isn't a study, it's merely an anecdote -- but you might find it relevant: "Testing a Thirty-Year-Old Photovoltaic Module."
  4. nickdefabrizio | | #7
    As someone who has PV, mini splits, heat pump hot water heater, electric cars and zero turn mower, I am confident my PV panels will be cranking out electricity long after the rest of the stuff will be decommissioned. NO moving parts is a beautiful thing......
