Article
A Fast Foundation for an Addition
Thanks to interlocking foam forms, you can form, pour, and insulate any small foundation in a single day
Insulated concrete forms require no special tools, can be set up quickly and are accessible to do-it-yourselfers. A veteran concrete contractor takes us through the process of installing the forms and pouring the foundation for a family-room addition. Rebar installation and proper bracing are both discussed.
A-Fast-Foundation-for-an-Addition_FHB170.pdf
