How to insulate 100 year old house from inside with no vapor barrier on the outside.
![](https://secure.gravatar.com/avatar/0a4d732e413e8a26755176caabb14ed5?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
I’ve been reading for days on how to go about insulating a room I demoed down to the studs. House is 100 plus years old and has aluminum siding over original wood siding and no WRB. I can insulate the ceiling without issue because I have a walk up attic above. I furred out my stud bays with lath to match the existing molding depth. My stud cavity depth is now measured just a tad over 4 inches. I don’t want to fur out the walls any farther. I am in Buffalo, NY which from my research is climate zone 6. I know I need an air barrier for drying out moisture but how much? With only 4 inches of cavity should I just use 2 inches of foam board and have back two inches air space. Do I use EPS or XPS? I’m just looking for my best option. R value doesn’t need to be perfect I just want to add something. I also thought about 1.5 inch foam board and ROCKWOOL sliced in half the long way 1.75 inches. That would leave me 3/4 of air space against the back of the sheathing. Stupid idea ? Thoughts and recommendations on what I should do ?
Bamfer9duce,
You may find this article useful: https://www.greenbuildingadvisor.com/article/insulating-walls-in-an-old-house-with-no-sheathing
