Green Basics
Green Heating Options
Green Heating Systems Can Heat the House and Its Water
ABOUT HEAT AND HOT WATER
Most houses need equipment to stay warm
When the sun is shining, a passive solar house design can take advantage of available solar heat. But in many climates, winter days are short and winter weather is often cloudy, so passive solar gains are rarely adequate to keep a home warm all winter long.
A heating system strongly influences a home’s energy use. Only three things have a greater effect: air sealing, insulation, windows.
  • Green Basics
    Water Heating
    UPDATED 04/05/2012Tank or Tankless: Reduce the Load to Lower Water Heating Costs
  • Green Basics
    Solar Heat
    Solar Collectors Can Heat Water and Living SpacesUPDATED 9/29/2011
  • Green Basics
    Heat Pumps: The Basics
    Heat Pumps Use Heat in the Air, Earth, or Water to Heat a House
  • Green Basics
    Cooling Options
    To Cut Energy Costs, Look for Low-tech Cooling First
