Q&A Spotlight
How Safe is PEX Tubing?
Does this widely recommended type of plumbing contain hazardous materials?
Hidden dangers in PEX?
Cross-linked polyethylene tubing is gaining ground in residential plumbing systems, but a poster wonders whether chemicals leach out of the material into drinking water.
Image Credit: Fine Homebuilding magazine
Builders have climbed on the PEX bandwagon in droves. Cross-linked polyethylene tubing is increasingly taking the place of copper in residential plumbing systems for a variety of reasons: ease of installation, resistance to acidic water, and the virtual elimination of leak-prone fittings.
It all adds up to a juggernaut for a building material that’s only been available in the U.S. since the 1980s.
But Arlene DiMarino isn’t sure about the safety of PEX.
“I am very concerned about using PEX tubing for water supply in my home,” she writes in a Q&A post at Green Building Advisor. “I was told that this plastic was BPA [bisphenol A]-free but when I did some reading I found out that there have been some reports of MTBEs and some VOCs [volatile organic compounds] leaching from this plastic.” (To read similar Q&A threads, see PEX vs. copper, Water supply: PEX? and Should I consider PEX?)
Her plumber is pushing for PEX. Should she go along?
The evidence either way seems slim
This forum specializes in the sometimes arcane world of wall assemblies, thermal boundaries and moisture management, not plastics, suggests J Chesnut.
“The effects of the many varieties of plastics is not a subject that GBA can offer much insight,” he writes. “I think it is an important topic but haven’t found a source for information or discourse I feel confident in.
“BPA seems better understood than many other aspects of plastics in that it does enter a body by leaching into water,” he adds. “I recently worked on a house for a physician where we had these discussions. The physician decided to take his chances with the copper supply lines instead of PEX, accepting the premium in cost.”
Steve El says evidence pointing to…
51 Comments
  1. Robert H | | #1
    Why is it that individual
    Why is it that individual lines to each tap are run from the manifold. It seems that this would promote water sitting in lines longer and having a longer chance of absorbing chemicals. My kids are not going to flush a line before drinking or brushing their teeth. I see the convenience of shutting off a leaking tap from a central, easily identifiable location.
    Also if I just took a shower and that run is full of hot water and I move to the sink to shave I now have to purge the cold water from another line to get hot water. Now multiply that by 2-3-4 bathrooms.
    Response to Robert
    Robert,
    Although many PEX plumbing systems use the central manifold, home-run approach, it's not a requirement. It's perfectly possible to use PEX with a traditional trunk-and-branch system if that's what you prefer.
    Conversely, it's also possible to design a central manifold home-run plumbing system using copper tubing -- although it's rarely done.
  3. Katy_Hollbacher | | #3
    PEX approved for use in California as of August 18, 2010
    FYI, PEX actually IS currently allowed to be used in CA:
    http://www.documents.dgs.ca.gov/bsc/pex/2010/Final-EIR/IB_10-01-PEX.pdf
    "This information bulletin is being issued to highlight an action taken by the California Building Standards Commission (commission) on August 16, 2010, concerning cross-linked polyethylene flexible plastic pipe, commonly referred to as “PEX.” The action taken removed the state’s amendment that excluded the use PEX for water piping systems from the 2007 California Plumbing Code, and to amend the 2010 California Plumbing Code... The Commission's action allows the statewide use of PEX in hospitals, clinics, schools, residences and commercial structures. The effective date of this action is August 18, 2010 for the 2007 CPC and January 1, 2011 for the 2010 CPC. "
    More details/documents:
    http://www.bsc.ca.gov/pex.htm
  4. T7sX5ebany | | #4
    Safety of Plumbing Materials
    What are the particular pros and cons for stainless steel ?
  5. user-757117 | | #5
    Great question.
    I'm considering the purchase of a stainless hot water tank.
  6. Michael | | #6
    Go tankless!?!
    Why would you get a water heater tank unless you have issues with the exhaust of a tankless. When you talk about water sitting in a location all I think about are HWH tanks.
  7. user-757117 | | #7
    Many reasons...
    1. I don't have access to gas unless I want to install a propane tank and I don't want an electric unit.
    2. I am on a well and I'm not so sure a tankless heater will like the water.
    3. I need energy storage for solar thermal and wood stove thermosyphon.
    4. I have a family and I'm not so sure that tankless heaters are any more efficient given the number of users... standby heat loss from the tank is within the thermal envelope.
  8. Doug on the Oregon Coast | | #8
    Tankless Water Heater
    I tried a tankless water heater several years ago with a well and had buildup problems. The only thing that showed up in the well water tests was excessive calcium, but the tankless was completely shot in 4 years. Unless your well water imitates city water without the fluorine, I would think twice about tankless.
  9. Bill Hanlon | | #9
    water heater discussion
    I put a whole house sized water filter in front of a tankless heater a number of years ago and have had no problems since. You have to do the annual maintenance though.
  10. Anonymous | | #10
    PEX and water quality
    http://www.healthyheating.com/Page%2055/Presentations/How%20Pex%20is%20made.pdf
    PEX pipe has been around for several decades and has been tested for compliance with NSF/ANSI Standard 61 Toxicological Evaluation for materials in contact with drinking water; health effects.
    I'm surprised that GBA would publicize this kind of question and leave it as unresolved as you have. The research to discover this type of information would have been a light burden for the author and experts in this area are easily found.
    PEX is safe for potable water so long as it is rated as such. There are some PEX types that are not. They are easy to distinguish from one another.
  11. Frank Hanlan | | #11
    Re: Sensitivity to BPA or Toxins
    Thanks for the serious consideration of this issue and resulting great discussion.
    We tend to generalize mainly based on our experience supplemented by research we have done or have read about. What we don't tend to pay attention to or recognize is that we are all different. We, therefore, often ignore and/or discount the very small percentage of people who are highly sensitive. ie only 1 - 5% of people maybe highly sensitive to emf radiation but due to its increasing prevalence it may be difficult to function.
  12. Anonymous | | #12
    BPA in PEX (potential risk)
    The strongest concerns about BPA center on its established action as a "endocrine mimic" -- that is to say, it's surface chemistry is close enough to that of estrogen that certain cellular receptors respond to the presence of BPA in a manner similar to the presence of estrogen. [Before you guys freak out; if you have fat on your body, that fat is already naturally producing low levels of estrogen.] The greatest concern is for developing embryos and pre-pubescent/pubescent children. I have read no definitive medical or scientific opinion as to whether this quasi-endrocrine activity actually upsets or distorts normal developmental processes in humans. There is, however, a strong concern that we are using our children as defacto "lab rats" and the answers may only come twenty to forty years down the road. There are well documented cases of industrial chemicals causing reproductive problems and greater incidences of cancer in the children... and even in the grandchildren... of women exposed to those chemicals. So, as previously said, we're doing the experiment right now. [Stay tuned for the next fifty years to find out who was right.] In the mean time, for all potable water I'll stick with copper pipe and lead-free flux. Builders have been using copper pipes for at least three generations, and so far, so good. Also, copper is a natural trace element in our diets.
  13. Joe_Bob | | #13
    objective information
    I just have to comment on the link provided by Anonymous at 12/15/2010 - 17:34 because I think it's hilarious. It's a PowerPoint presentation put together by the Plastics Pipe Institute, a plastic pipe trade association. I'm supposed to rest on the reassurances of the Plastics Pipe Institute? Really?
  14. J Chesnut | | #14
    material impacts
    Impacts on occupant health is only one important aspect of weighing the pros and cons of material choices. Other issues include: what happens at the end of the products life cycle, what are the environmental and health consequences of the industry that produces the materials.
    Also the industry that installs the materials have their own sets of health related issues.
    I have plumbers in my family. Years of working with PVC piping and their associated adhesives and soldering copper piping have likely had consequences to their health to a greater extent than how an occupant might be affected by tainted water.
    I once heard a talk by a former plastics chemist at 3M. I don't remember all the details but the impression I was left with is that their are people who understand the chemistry between materials in our environment and how they are introduced into biotic systems. However we don't have access to this expertise to explore the concerns we have and make intelligent decisions as we contribute to the built environment.
  15. homedesign | | #15
    Hi Scott
    Hi Scott,
    I really enjoy your Blog.
    edited due to rethinking
  16. Russell D | | #16
    Clean Water
    This is so all overblown, be glad you have clean water to drink. Most 3rd world countries are happy if they can find clean water. We all worry about the stupidiest things. Just live your life & find something to be thankful about.
  17. Anonymous | | #17
    PEX
    All of you are too untechnical
  18. wjrobinson | | #18
    PEX installation
    I have three systems for putting PEX together. Uponor is the best to me. But there are occasions where the Watts crimp is fast or even better yet, use the push on o-ring connectors such as when one has to repair something quick and or under extreme conditions, IE cold.
    Cold PEX does not like being connected leak free. The plastic is harder and doesn't form perfect seals always. I have had Watts cold assembly weather leaks and the Uponor stretch to fit has issues with time before pressurizing and cold temps. If I use an Uponor fitting in cold weather, I need to heat it up a bit and also will put a hose clamp over the top that I leave on for a day if pressurizing right away. That gives the PEX time to shrink and make a good joint. I learned all this on the job as I went, would be nice if these little hints were printed up and placed with the fittings and tools at purchase. Hope this helps the next person learn ahead what I learned over my first two homes.
    Oh and more, Uponor has integrated sprinkler system parts, and plastic fittings that are my choice also. There has been quite the issue with yellow brass fittings that are sold at the big boxes failing for various reasons.
    I do not work for Uponor. Though I would love it if they sent me a ProPEX® 150 Battery Expander Tool.
  19. Anonymous | | #19
    PEX is great. Home runs are great. Use filters.
    Our house is converted to a PEX home-run from a manifold system. It works great. Pressure and flow equalize immediately without special valves to prevent scalding. There is no bi-metal galvanic action. The tubes withstand occasional freezing. I have had no leaks. Properly maintained reverse osmosis 5-stage filter provides high quality drinking water that tests very well. Aerators do not clog at all, and last. Several simple options are available to eliminate the hot-water lag. See Watts Premier for examples of filters and hot water recirculators.
    1. user-1116814560 | | #51
      I thought manifold systems obviated the need for temp/pressure shower valves ?
  20. Henry | | #20
    No more Pex for me
    I recently built a home using Pex and had a mouse chew five holes in various places through the piping. Thousands of dollars worth of water damage was caused and now it is a constant worry that it may happen again. I have gone back to using copper.
  21. Max | | #21
    Like the previous commenter
    Like the previous commenter said, why not put a high quality RO system before your drinking water tap and be done with it? Seems like much ado about nothing.
  22. Phil H | | #22
    History
    When it comes to plastics, we really don't know "what we don't know". We are finding out every day new risks and adverse reactions due to plastics. The north Pacific Gyre is only now at the beginning stages of study. Ultra-violet degradation is not fully understood and plasticizers like BPA are only the tip of the iceberg. When talking about adverse health effects, there are many that are not at all obvious..
    Cancer is an obvious effect because we can "see" the results, ie death. What we don't see are much more subtle biological consequences of the use of plastics. Some things are not understood, or even addressed except in obscure medical and scientific journals. Things such as fertility, hormone imitating, cecadian clock disruption, etc. But not just in us, but in the whole ecosystem of which we are only a part.
    When it comes to "new" products we introduce into our environment we rarely look at all the long term effect possibilities, just the ones that are obvious.
    As a remodeling contractor, I cannot, in good conscience, recommend PEX for potable water, although it is practical for space heating.
    Phil
  23. DoubleDonn | | #23
    PEX and "chemicals"
    Every time I see the statement, usually made with horror or in disapproval, that something contains chemicals, I can't help but wonder if the maker of the statement is aware that every material object in the entire universe is made entirely of chemicals. Name one material that is not a chemical. Relative to toxicity, it all depends on the context. Sodium (the element) is highly dangerous to ingest. Chlorine (also an element) is poisonous to inhale. Chlorine is a key constituent of many poison gases. Yet without the proper mix of Sodium and Chlorine ions in our blood, life is impossible. Go figure. Most "natural" foods contain sodium and chlorine as well as a host of other "chemicals" almost all of which have regions of toxicity. You need oxygen for minute to minute life, yet too much oxygen at certain times of fetal development is highly unhealthy. Without body regulation of copper, a terrible disease (Wilson's disease) results. The list goes on and on. The point is the word chemical has been allowed to become pejorative rather than descriptive and an unwarranted shorthand for dangerous. As far as the leachables from PEX or other forms of polyethylene, I personally don't worry as I have dozens of years of successful experience using PE and PVC in medical applications but I am counting on the products being as stated by the manufacturer insofar as proper formulation is concerned. Just as with lead solder and copper pipe. Remember the gypsum board from China; it wasn't the gypsum it was what else had been added.
  24. Jack | | #24
    'Chemicals'
    As Dow used to advertise 'Chemicals for Life'. Chemicals like DoubleDonn said are 'natural', how we use them is up to us, and many of us (most1) don't understand the implications of long term exposure. ... The Romans ran lead pipes as the latest technology to the homes of the rich. The rich turned crazy from lead poisoning and they had no way of knowing. ... I think we are the same way about using ANY pipes or containers for our food and beverages. ... Ok, to the point... I think we should be cautious, but don't do the 'chicken little' thing and call 'the sky is falling' just because there is a newer technology. ... If we wanted to be 'real safe', currently non-sodium glass pipe or pure virgin polyethylene seems to be the way to go. Now most of us can't afford it, and it will take special maintenance and environmental considerations, so it is just not 'practical'. Copper has a current cost issue, PVC has a 'chemicals' issue, and PEX (appropriately rated) is pretty good.
    No system is 'permanent'. A hundred years or so, and any system we have installed needs to be replaced (whether thermal, environmental, support systems, etc, etc) some several times.
    What is the right thing to do, IMHO, it is make a good 'reasonable' guess with todays technology and go on, realizing we will guess wrong on occasion.
    What would I do today in a house for me and my family? PEX probably.
  25. Anonymous | | #25
    PEX and brass fittings
    Our water supply is treated with chloramine salts rather than chlorine. Significant leaks can occur where PEX piping is used with brass fittings with this kind of sanitation chemical. The chemical interaction produced between the PEX, brass and chloramine salts eats away at the brass with corrosion occurring, small leaks turn into big problems over a short period of time. Caution should be taken to find out how your water supply is made safe. Within 6 months from finishing our new home, you could easily see the corrosion inside the brass. This fix was an additional pre-treatment filtration system at $6K. All copper would have been far less expensive.
  26. David | | #26
    PEX/copper???
    Face it people if man makes it, there is always a potential for harm. Quit over analyzing everything. Use what you can afford or are comfortable with and enjoy life!!!!!!!!
  27. Anonymous | | #27
    PEX
    The suppy lines underground are increasingly becoming plastic because transite pipe is hazardous to handle and easily damaged. The laterals off the main are often polyethylene, are we creating a monster, or are the new products impact on the labor market more worrisome? The medical community is not my first choice for reference. The AMA and FDA are constantly removing approved medications and products from the market that extended some peoples lives and may have harmed or killed other people, yet were administered by competent, educated professionals with good intent resulting in expensive litigation. Mabey the legal community can get more involved and make plumbing like our health care, unaffordable. We are living longer due to the quality of life many plastic products deliver. The news carried a report that the water source in Las Vegas has been found to contain concerning levels of hormonal drugs that cannot be fitered out, they have been reintroduced into Lake Mead from water treatment plants, that would worry me more.
  28. Anonymous | | #28
    Follow the money trail for this one.
    a few additional points:
    Never use water from the hot lines for internal consumption for a far more important reason: the hot water tank is at a perfect temperature to multiply all kinds of organisms we don't need or want in our systems. Of course, I don't really consider any tap water to be "safe" for drinking except possibly limited quantities in an emergency.
    PEX's chlorine resistance [and fluorides] is purely because there is some kind of organic sacrificial compound mixed in with the polyethylene to be preferentially consumed. When that is gone the game is over. That consumable material has to be some sort of organic material, any of which also makes for less than healthful compounds in the water as a result.
    Out of the blue they are saying PVC pipe is worse with no indication as why they would say such a likely erroneous thing.
    No mention whatsoever of CPVC which has been used for over 40 years with no known deleterious effects or degradation in millions of installations.
    I consider a nominal 20-40 year life expectancy for the plumbing to be even worse than galvanized pipe [nominal 40 year life expectancy] when homes are expected [erroneously] by the public to last far longer than that. Are we ready to abandon our houses because they are beyond the design life expectancy [15 years]? I don't think so.
    The suggestion of polypropylene as an alternative is humorous on the face of it as that material is at least as sensitive to oxidation as polyethylene.
    The insertion of the European use of PEX fails to mention that they don't typically put oxidizers like Cl & F in their water, so no such usage comparison is valid.
    The author also conveniently ignores the polybutylene plumbing fiasco in years past, and the several statewide law suits already under way and ending of warranty payments because of serious PEX malfunctions.
    As a home inspector, I have never seen it installed properly [according to instructions].
    All in all the article looks like an attempt to whitewash PEX concerns with no evidence and lots of misdirection.
  29. GBA Editor
    Martin Holladay | | #29
    Response to Anonymous
    Anonymous,
    You wrote, "I don't really consider any tap water to be "safe" for drinking except possibly limited quantities in an emergency."
    What country do you live in? I've lived in countries like that.
    However, in the U.S. and Canada, tap water is safe to drink.
  30. dorr tippens | | #30
    PEX hazards -
    SHAME on the editors. The suit referenced was dismissed due to ridiculous claims including the comparison of MTBE release from unrelated plastics to PEX, improper installations &c. This type of yellow journalism might sell copy but misinforms and misguides the public. I am SHOCKED at the disservice done by this article and how the editors didn't vet the content. This causes me alarm now in not trusting anything (certainly not at face value) that I read within the Taunton Press family.
  31. GBA Editor
    Martin Holladay | | #31
    Response to Dorr Tippens
    Dorr Tippens,
    While litigation delayed the implementation of regulations designed to permit the use of PEX in California, the litigating parties have agreed to a settlement. More information is here:
    http://www.documents.dgs.ca.gov/bsc/pex/2010/Settlement/PEXSettlement08-18-10.pdf
  32. Anonymous | | #32
    Stainless Steel
    Timmy O'Daniels asked about the pros and cons of stainless.
    My first and foremost concern with anything stainless these days would be quality control. There are many different alloy formulas, and lots of ways for shoddy makers to cheat. So much of what is supposedly stainless now eventually shows red rust marks.
    Cutting and fitting would be the next big issue. Ask a room full of machinists what their least favorite material is, and the shout in unison will be "Stainless!" Most grades of stainless work harden. You can't cut it with a wheel cutter like copper, PVC, or ABS. It dulls saws quickly. You might best use an angle grinder. In that mode, you'd have to braze the fittings. It's like soldering copper, only much hotter, which means an oxyacetylene torch and more fire danger, etc. There are free machining grades of stainless, but they're expensive, and not all that easy to cut. Another approach might be to use NPT threads, but plumbers would have to stock two types, pre-threaded long lengths, and free machining for the stuff that they cut and fit. Because you need to plan and have room for things to turn, threaded work is more labor intensive. Compression fittings would work, but code doesn't allow them inside walls.
    Stainless tubing is a low volume product today, but given similar economies of scale to copper, it would ultimately be cheaper.
    We already use some stainless parts, mostly on the ends of those braided tubes for water heaters. In that application, it holds up just fine. Electrochemically, it plays nice with copper, brass, and galvanized, which is why it's good there.
    That just scratches the surface, it's a big subject.
    -- J.S.
  33. Anonymous | | #33
    Big Box Yellow Brass Fittings
    AJ Builder has had some trouble with them: "There has been quite the issue with yellow brass fittings that are sold at the big boxes failing for various reasons."
    So have I, two really hellish kitchen faucet jobs. The problem turns out to be with 1/2 NPT male threads on brass stuff made in China. The crests of the threads are cut away, leaving a long narrow spiral path when assembled through which you get a slow leak. No matter how much tape or compound you use, or how hard you tighten it, in a few days it'll leak.
    -- J.S.
  34. Andy Betteridge | | #34
    Copper pipe self disinfecting properties
    I am over in the UK and over here there are considered to be benefits to copper be naturally self disinfecting, here are a couple of examples.
    With water being stored after heating with for example an air source heat pump the water temperature is not sufficiently raised to prevent bacterial growth, however if stored in a copper cylinder rather than a stainless steel one the risk is reduced, generally though an electric water heater is employed to add extra heating on a periodic basis to kill in any bacterial growth.
    A hospital in Birmingham UK is replacing plastic waste pipe lines and traps with copper to see if the self disinfecting property of copper can assist in reducing MSRA infections.
    I generally work on existing systems and use copper pipe and lead free soldered fittings, but if the existing system is plastic then I add to it in plastic rather than making the change to copper, partly due to electrical earthing requirements.
    Andy
  35. kaymc | | #35
    Pex is OK
    As a residential contractor and home-moaner :-) and a recent convert to PEX from copper, a critical point would be the installer themselves.
    On the previous customer project the plumber in his infinite wisdom, ran 6"pvc as a conduit for both the hot and cold lines thru the crawlspace from hot water boiler to bath sinks and tub, a run of around 20 feet. Needless to mention that a hot water pipe in contact with a cold water pipe becomes less capable of delivering hot water.
    I would think that commuting daily on the road thru rush hour, just by itself allows us to ingest multiple chemicals which are themselves inherently more toxic than copper or PEX.
    On the " cry wolf " itinerary from some who have read unsubstantiated reports, it truly becomes a waste of time to read their concerns.
    Any new application always needs an assessment period to work out the bugs, I believe PEX has been around long enough for me to consider and install a full system in my own home and also to recommend it to clients.
  36. Anonymous | | #36
    pex vs. copper
    I work in the plastic processing industry & without going into long detailed studies, these are some of the realities:
    PE, PP (& PEX) are porous and can harbor bacteria, mold or fungus. I use PEX for underfloor heating, but prefer copper for potable water. CPVC ("C" is clorinated PVC) and can be used for hot or cold water, and although less porous than PE or PEX will allow the formation of mold, mildew, fungus, etc.
    Copper & galvanized pipe are not porous and will conduct enough static electricity to subdue mold & mildew. There are other problems that can develop due to electrolysis such as lime deposits, corrosion, etc.
    I purchased a dozen polycarbonate (bis-A) water bottles after BPA got bad publicity. Don't boil in polycarb or store acidic foods in them. Drinking water, cold liquids or alcohol can be stored or carried in polycarb. Most people with traces of bis-A in their tissue probably got it from the epoxy liner that was used to prevent botulism in tin cans.
    More than 50% of the residences in the city of Chicago have lead pipe feeder lines running into their homes. Lead is an actual threat to your health.
    The best thing to do is to have the water analyzed after the system has been running for a year.
  37. Anonymous | | #37
    Filters
    Someone else mentioned it briefly but is there any issue with using a good filter, replaced a couple times a year, at the point of use to eliminate lead and the other nasties? Aquasana makes the point that clorine keeps bacteria from growing in the pipes in the distribution system yet drinking bleach is not a good thing :). So, while I'm a bit suspicious of taking advice from someone selling water filters, eliminating clorine, lead and etc at the point of consumption would seem to make sense since it is after all the pipes which *could* add lead, bacteria and various other harmful materials.
    Showers are a bit more difficult to filter because carbon filters don't work well with hot water but there are filters that remove a significant amount of the clorine and other chemicals. Does anyone have a better solution for them?
  38. DonAtlGa | | #38
    Filters
    I have been involved in residential and commercial plumbing as a licensed plumber since 1978.
    My current preference is to install a 20" canister 5 micron filter followed by a whole house (loose media)granulated carbon filter at the service entry point. This catches any scale coming from the city mains, then removes most of the chlorine (etc) that the county adds for purification. As a bonus, the carbon also catches many of the trace chemicals that we have managed to add to our water supply. The larger filters boost efficency and reduce maintenence requirements dramatically. Total retail with the plumbing included is usually in the low $2000's depending, of course, on system size.
    . Over the years I have had to sanitize a couple of hot water systems to kill off bacteria growing in water heaters (none had filters, but most if not all had been sitting unused for some period of time). I would side with the previous posters who recommend not drinking or cooking with the hot water in your home
  39. DonAtlGa | | #39
    Pipes
    Sorry - missed your point of use point. Point of use are lots better than nothing - but you are correct in that they won't help with your showers. I haven't found a hot water chlorine filter - sediment only , as far as I know.
    FYI -you should use a seperate tap (or two handled kitchen faucet) in the kitchen, as single handled mixing valves will almost always mix a bit of unfiltered water in with the filtered.
  40. Dr Juan | | #40
    Pick your poison
    PVC: contains several percent phthalate plasticiser that will forever be leaching from the pipe walls along with very minute traces of VCM ( vinyl chloride monomer), a liver carcinogen.
    Copper: heavy metal contamination from lead solder and brass fittings - now avoided using lead free solder and brass.
    PEX: Actually there are several versions, chemical crosslinked and radiation crosslinked. The radiation crosslinked versions are relatively clean and worry free. In fact the radiation treatment is similar to that used on some artificial hip sockets to extend wear life and has been deemed implant worthy by FDA. To the contrary, chemical crosslinked versions are of real concern since the brew needed to create the crossinking reaction in the extrusion line is pretty dangerous stuff. I would avoid it myself.
    Barrier PEX: Barrier layers of special plastics or aluminum foil are used to keep oxygen from diffusing into the water within the pipe and corroding boilers. This is useful for radiant hot water and baseboard heating but is not needed for potable water home plumbing. But the Aluminum layer might give better UV life if the product is approved for potable water. Unfortunately, last time I looked, most of the foil wrapped versions are chemical crosslinked. But the scene changes yearly so do your homework and your own investigations. These barriers are useful with underground feeders for drinking water that must traverse badly contaminated land. The barrier can significantly reduce leaching of ag chemicals into the water line.
  41. 2DSER2XktY | | #41
    New paper published
    Here is an interesting paper published late 2011 on leaching from various plastics:
    http://ehp03.niehs.nih.gov/article/info%3Adoi%2F10.1289%2Fehp.1003220
    Could do with a more independent (not funded by a plastics company) study to confirm the results.
  42. BGreene | | #42
    To add to the debate ...
    New
    New research finds that copper in amounts readily found in our drinking water, the foods we eat and the vitamin supplements we take likely plays a key role in initiating and fueling the abnormal protein build-up and brain inflammation that are hallmarks of Alzheimer's disease.
    http://www.latimes.com/science/sciencenow/la-sci-copper-alzheimers-disease-20130819,0,5977613.story
  43. RAHra | | #43
    PEX vs Copper 2014 Comment
    Seems this article gets a comment a year still, let me do the 2014 comment.
    PEX - This is where a gov't study, ala the old days when there'd be a gov't dept with workers who knew their jobs were safe for life no matter what they found, would help. Now, who can you trust? Hence, endless, and mostly pointless debate.
    Some good factoids though, 2 wks of sunlight exposure may result in chlorine?? decaying lines and blowing them out quickly. Vermin do eat PEX. Another reason for whole house treatment of soft water is to extend life of copper and prevent possible illness from dissolved copper. Municipal gov'ts are saving big bucks using PVC for water supplies - and there's more chemical leaching with PVC than PEX. There are different types of PEX, some as safe as medical implants, some made with witches brews of chemicals.
    Codes allowing, I'd give this to the client, a price for PEX vs. Copper, and let them pick which.
    For my home, I use copper.
    There's the survey to take of builders and plumbers, what would install in your own home, PEX or Copper?
    Russell Higgins AIA
    Roughdesigns
  44. geodrone61 | | #44
    Environmental Cost of PEX
    PEX is a petroleum based product, as are all plastics, and as the article points out, it can't be recycled or safely burned. But this has to be weighed against the environmental footprint of refined copper itself- as a geologist I've toured two copper mines in the southwest and countless oil drilling rigs in the Bakken oil field. All resource extraction comes with significant (and usually ignored) environmental costs, but I have to tell you, ANY rock mining operation, be it coal, copper, or steel, does FAR, FAR more lasting environmental degradation than oil drilling . Once you've seen the open pits, the scarred landscape, and the pools of toxic, acidic water required to produce copper and realize these features are more or less permanent, you may come away with a different perspective on the environmental footprint of PEX.
  45. billnewcomb | | #45
    Blistering and splitting of PEX 5006 tubing.
    My hot water heating system, installed less than four years ago, has a plethora of blisters and splitting of the outer surface of the PEX 5006 tubing. This tubing has been exposed to nothing except basement air. I believe that I have a bad batch of tubing, but all of the other complaints that I can find, of such splitting have been viewed as minor and dismissed, by so called experts. I have to have all the tubing replaced, which I do not consider minor.
  46. GBA Editor
    Martin Holladay | | #46
    Response to William Newcomb
    William,
    1. Can you post photos of the damage you are describing?
    2. What brand of PEX is it?
    3. Have you contacted the contractor who installed it?
    4. Have you contacted the tubing manufacturer?
  47. Mtnlyon | | #47
    Safety of PEX for drinking water
    I want to respond to the people who said things like "have you seen your neighbors drop dead from using..."
    Lead, and asbestos and a list of other toxins, don't cause people to drop dead immediately, but we acknowledge their danger. Of course most US tap water is safe for immediate consumption, but it's the long term and cumulative consumption that is the worry. Even if not toxic, we consume things that have negative effects on nutrient absorption.
    This attitude of if it doesn't kill you immediately, it must be safe is a big problem, since most of the carcinogens we are exposed to are manufactured by companies and regulated by agencies that know that even if these products contribute to cancer, there is no way it will be traceable to their product, 10, 20, 30 years out, especially since they can argue that there are so many other carcinogens it could have been. Most of the diseases that are killing Americans are coming in through our mouths; heart disease, cancer and diabetes.
  48. GBA Editor
    Martin Holladay | | #48
    Response to Curt Lyons
    Curt,
    Your comparison of PEX water tubing to lead and asbestos is totally without basis.
    Public health researchers have collected excellent data on the toxicity of lead and asbestos. In contrast, no reputable researcher has come up with any similar data showing any toxic effects from drinking water delivered by PEX tubing.
    1. drafthunter | | #50
      Without basis? This study was done in 2014:
      https://www.purdue.edu/newsroom/releases/2014/Q4/drinking-water-odors,-chemicals-above-health-standards-caused-by-green-building-plumbing.html
      And Curt’s point was, which I think was valid, just like lead and asbestos, it was deemed safe at one point because people like yourself said there is no proof that it’s not safe. Well, where’s the “reputable studies” that it is safe for drinking water?
  49. magicis | | #49
    safety of PEX for drinking water
    Is this whole discussion somewhat superfluous, as the cities are replacing the old lead pipes with pvc pipes that bring the water to our house?
