Living in a Passivhaus
We’ve enjoyed comfortable interior temperatures and relative humidity, plenty of fresh air, and very low energy bills
Image 1 of 3
The author lives in this Passivhaus in Falmouth, Massachusetts. Designed by Steve Baczek, the house was completed in late 2013.
Image Credit: Image #1: Dan Roy
A view of the kitchen. The cooktop is an induction model.
Image Credit: Images #2 and #3: David Fell Photography
The living room.
[Editor’s note: Daniel Roy is one of the owners of a recently completed Passivhaus in Falmouth, Massachusetts. Designed by architect Steve Baczek, the house was featured in a series of GBA videos. For more information on the home’s energy specifications, see the attached Excel spreadsheet.]
We moved in to our new house on New Year’s Day 2014. We have found that living in a Passivhaus is fantastic, and the house performs as expected.
During our first winter, we experienced one of the most severe tests we will ever face in our Passivhaus. The cold “polar vortex” winter of 2014 was one of the toughest winters in many years. In spite of this, the house remained very comfortable.
On sunny days, the minsiplit heat pump stayed off
To us, comfortable meant temperatures from about 65°F to 70°F, relative humidity of about 40%, and of course no drafts. We found ourselves rarely using the backup minisplit heat pump. If the sun was shining during the day, the sun and internal heat sources (people, dogs, appliances, etc.) in the house were sufficient for us to remain comfortable all day and night, and we didn’t need to turn on the backup heat. Indeed, for our preference, we would have preferred a somewhat colder bedroom for nighttime sleeping.
If the day was cloudy, we turned on the heat pump, usually for an hour or two. We found that once the heat was inside the house, it wasn’t going anywhere very quickly. We found ourselves using the heat pump maybe once a week. Admittedly, we had some extra heating assistance from our other heat source, our 8-year-old plasma TV, which cranks out a warming 500 watts when we watch it in the evening. We have since replaced the TV with an LED unit that consumes only 120 watts.
Energy-stingy ways to stay cool
During the spring, we kept the windows closed most of the time to keep out the pollen and relied on the inlet air filtration of our ERV. Our ERV is equipped with a pre-cooling ground loop, and that system was usually sufficient to keep the house comfortable.
This summer, we experienced what it was like living in a coastal humid climate. With outdoor relative humidities consistently at 80% or higher, we wanted to keep the house at about 55% RH. We did this by running the heat pump in either AC (“cool”) or dehumidification (“dry”) mode through most of July and August. Our ceiling fans are equipped with high-efficiency DC motors, and we ran these fans much of the time. These methods kept the house very comfortable (75° to 78°F). In spite of this, our monthly electric bills went up by only about 100 kWh (or $20, based on our electricity cost of 20 cents per kWh here on the Cape).
During the fall, we typically open two or three windows on both the first and second floors to allow for natural stack-effect cooling, provided the humidity is low.
Fresh ventilation air
We love the idea of living in a house that has no combustion and 24/7 ventilation. This keeps the air fresh and filtered (when we keep the windows closed).
Everything in the house is electric, including the heat-pump water heater, the induction cooktop, the clothes dryer, and the backup heating and cooling systems. With the house so tight and insulated, we have found the interior to be very quiet. Only our dogs seem to be able to detect the faint barking sounds out there.
The wi-fi signal was blocked
One disadvantage of a tight house is that wi-fi signals are unable to penetrate the walls, just like the heat energy. Future Passivhaus buildings should have exterior Ethernet connections so that people on decks and patios can be online.
Another product which could use improvement is the condensing clothes dryer — a dryer does not exhaust to the outside. It is small and inefficient to run. With a Passivhaus, there is no simple non-mechanical way to use exterior exhausting products like conventional clothes dryers and range hoods. Even when we run our 120-cfm central vacuum cleaner, it is pulling a vacuum on the inside of the house. If we leave a window cracked, the vacuum airflow will pull it open. The reason is that there is no easy way to get the high air flows needed for these devices, unlike in a conventional house where the extra air is supplied by leakage through cracks and crevices in the house.
On track to be net-zero
We are on track to use about 7,200 kWh per year for our all-electric house. This is the same number of kWh we used in our previous conventional house, but at that house everything was gas (heat, hot water, clothes dryer, and cooking). The new photovoltaic system that we installed will generate about 10,000 kWh annually, enough to also power a future electric car and still have our new home be net zero. I should get about 10,000 miles with the 2,500 excess kWh that my PV system provides.
Dan Roy is a Certified Passive House Consultant (CPHC) with PHIUS and a licensed professional engineer (mechanical) in Massachusetts. He worked many years in various engineering jobs, but this is his first Passive House design. Dan wanted to live in his first design so that he could experience it firsthand and share what it is like living in a Passive House.
Falmouth Passivhaus.xlsx
5 Comments
  1. rjparker | | #1
    Make Up Air for Range Hood and Dryers
    Make-up air for range hoods and dryers is a big issue for all residential construction. Obviously the installed ERV is not capable of supplying adequate air volumes for range hoods and dryers. I wonder why passive home designs can't employ commercial style make up air for range hoods and dryers? Perhaps laundry rooms need to be sealed from the rest of the house to allow it's own makeup air. It would seem dryers could be designed with intake as well as exhaust air vents making that problem much easier to deal with.
  2. STEPHEN SHEEHY | | #2
    make up air
    For our new house, we're thinking about a heat pump dryer and a recirculating hood to avoid the make up air problem.
    The development of a ventless wood stove is on the same schedule as fusion power, so I guess we'll need a source of make-up air for it.
  3. user-1109130 | | #3
    condensing dryer
    We've owned an Asko condensing dryer for more than a year. We were prepared for some compromise in drying performance, but we have been pleasantly surprised by it's performance. I would not hesitate to recommend it.
    Although less convenient, locating the dryer outside of the thermal / air-tight envelope is another common strategy to allow use of a traditional venting type.
  4. wjrobinson | | #4
    Straube testing something nothing at all like David's
    Just looked at the Straube wall attachment details. 6 mil interior poly, wall had water leaks. End of story folks!!!!
    Take a sandwich bag put a tiny hole in it, hit the surface with rain, then call me when the inside of the bag drys out. Never. End of story.
    Martin, you and many of us... know interior 6 mil poly is asking for trouble, and it has been noted thousands of tract built homes will have a flashing leak or two or more... from day one or soon after...
    Straube and company do a lot of research to aid tract builders. Great work. I love the work. But lets all talk about apples and apples... or oranges and oranges.
    No one should ever build the wall that Straube posted where I live, ever.
  5. wjrobinson | | #5
    Follow the money
    Owens Corning, Georgia Pacific or little Cellulose manufacturers....
    Done, I rest my case, rebuttals welcome.
    Why aren't more homes sheathed in exterior drywall???? Gotta be something to do with the money trail in what we builders are marketed to use.... Martin? Dana?
